myrio camera
How do you use a webcam with the myrio?  I tried using a Logitech c525 camera and it does not register for me.
Message 1 of 41
(25,656 Views)
Hey cwatts26,
You'll need to install the NI Vision drivers on the myRIO before it will recognize a USB webcam.  You can install the drivers using MAX.
These links may also help:
https://decibel.ni.com/content/docs/DOC-30345
 http://zone.ni.com/reference/en-XX/help/373925A-01/myriohelp/myrio_vision_apps/
Let us know if you have more questions.
Thanks!
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
Message 2 of 41
(25,633 Views)
Correct me if i'm wrong
NI Vision Acquisition Software—Allows you to acquire images from USB cameras that you connect to the NI myRIO.
So i have to purchase the acquistion software?  to access webcam's.
i'm pretty sure the myrio does not come with it.  I already have the student version of devlopment module.
Message 3 of 41
(25,625 Views)
The myRIO Software Suite includes everything you need to get a USB webcam working with myRIO, so you don't have to purchase anything extra.  However the vision driver does not install on myRIO by default (you'll have to manually add it to the myRIO in MAX).
Let me know if that makes sense.
Thanks!
-Sam K
LabVIEW Hacker
Message 4 of 41
(25,622 Views)
I understand the Driver thing, maybe I'm downloading the wrong Driver, or do I need to download a Driver to the myrio itself?
I did install ni_imaq_USB. Driver to my computer, though it can be seen on image 2 of the file.
Also I view the license file and found the acquisition software, so it's only good until the 20th.
Message 5 of 41
(25,617 Views)
Hey cwatts26,
You need to make sure the driver is installed on the myRIO itself, not just on your computer.  Find your myRIO in MAX and expand the software section.  Are NI Vision RT and NI-IMAQdx listed?
Thanks!
-Sam K
LabVIEW Hacker
Message 6 of 41
(25,613 Views)
When the driver are properly installed on the myRIO and you connect a supported webcam you should see it in MAX under the Devices and Interfaces section of your myRIO.
-Sam K
LabVIEW Hacker
Message 7 of 41
(25,606 Views)
Once you get that to work you can use the Vision Aquisition Express VI in LabVIEW to aquire an image from the USB Web Cam.
-Sam K
LabVIEW Hacker
Message 8 of 41
(25,603 Views)
cool got those, but how do you install the driver's onboard then?
(sorry for the delay, adding attachment is hating me right now)
Message 9 of 41
(25,600 Views)
Details for install software to myRIO can be found here.
-Sam K
LabVIEW Hacker
Message 10 of 41
(25,597 Views)
