07-10-2015 03:48 AM
Hello Sammy_K. My name is Sergio. I have some troubles with the vision libreries for miRIO. could you help me guiding me to install the miRIO software suit? I installed the miRIO LabVIEW 2014 that comes with the hardware but I have looking for the drivers and haven't found them. Please I am a little delayed with my proyect.
07-13-2015 10:11 AM
SSheko,
You can find the base software here:
http://www.ni.com/product-documentation/14603/en/
If you have a specific problem I would recommend starting a new thread. This one will no longer show up under new posts, and we prefer new threads so we can track the number of issues that people are having.
09-15-2015 08:56 PM
one question, does it matter if it is connected to the computer USB or the myRio ? cause it works in my program when i connect it to the computer USB rather then the myRio.
09-17-2015 09:20 PM
it dosent matter
12-25-2015 05:26 PM
salam
Je travaille mon projet sur la carte NI myRIO .
Pour acquérir et traiter une image par NI myRIO j'ai besoin d'installer les drivers NI Vision RT and NI-IMAQdx dans la carte elle même et non pas seulement dans le PC , mais quand j'ai suivi les étapes de cette tache je trouve que je suis en face d'un problème de mot de passe et je ne sais pas d'où je peux le récupérer.
Pouvez-vous m'aider s'il vous plait ?
12-29-2015 09:59 AM
Hey Amelchehbani,
Did you inherit this device from someone? Maybe they have the password. Try googling how to reset the password.
Also, it helps to write in English if you can. Google translate can only help so much.
Au revoir,
Bear
04-09-2016 02:37 AM
if driver is not installed.then how can i installed driver in myrio??
04-11-2016 11:00 AM
As was linked above, if you need the software for the myRIO, it can be found at the following link location:
Required Software for NI myRIO
Also, I would recommend starting a new forum post if you have new questions. Good luck!
07-28-2018 01:30 AM
Option of Software under devices and interfaces is not showing. Kindly tell me whats the problem
@Kristoff2 wrote:
Hey cwatts26,
You need to make sure the driver is installed on the myRIO itself, not just on your computer. Find your myRIO in MAX and expand the software section. Are NI Vision RT and NI-IMAQdx listed?
Thanks!
-Sam K
Join / Follow the LabVIEW Hacker Group on google+
07-30-2018 10:24 AM
Hey Mohsin,
Not sure if you mean that you don't have software stack under the software drop down, but you can always right click on software and select Add/Remove Software to see what is installed. When the stack doesn't populate even when there is software installed it's usually a network issue.
-Bear
