02-14-2014 05:47 PM
Your awesome. I ended going through MAX and removed 4.3 then installed 4.2. Works like a beast!
For someone being new with the rio and being patient with me, I just want to give you a huge thanks. I was literally jumping around when i took a picture. Once again, THANK YOU SO MUCH.
Caleb
02-15-2014 07:39 AM
Hey Caleb,
I'm happy to help. I think the install order was what confused things but I think it should still work with IMAQdx 4.3. I'll follow up and see if there is a bug there or just something we didn't understand.
-Sam K
Join / Follow the LabVIEW Hacker Group on google+
02-17-2014 11:08 AM
hi what says Sammy_K is true, you can have problems backwards compatibility and can also be a problem that the camera required drivers or additional installers and despite having the sets of suitable tools can continue to have problems, we could work with a standart camera low resolution?
10-17-2014 07:04 AM
is it possible to use the same set of drivers on sbRIO 9636 for a USB webcam?
I think it has the same OS, USB, only the CPU is different.
I can see the USB device, but not as an IMAQ camera.
Older posts says it was not possible, but there should be new drivers...
Thanks a lot.
10-20-2014 10:32 PM
NeoGHOST,
I wanted to let you know that I don't have an immediate answer, but I am currently researching this issue and should have more information soon.
10-22-2014 05:36 PM
Hi All,
The latest request from Neo is answered here: http://forums.ni.com/t5/Real-Time-Measurement-and/sbRIO-usb-camera-driver-from-myRIO/m-p/3026885#M15....
Joseph
03-08-2015 04:43 AM
Hey,
Can someone please help me out here !! I was wondering whether i can use optical flow cameras with myrio. To be more specific, can i use PX4 flow smart Camera?
Cheers
05-01-2015 07:57 AM - edited 05-01-2015 08:05 AM
I have a similar problem with imaq and camera. The problem is I can't connect with my camera. I can see it on the MAX list (4.png attachment) or in Vision Acquisition block in LabView but it's impossible to snap any image. When I am trying to acquire an image I have error like in the 5.png attachment.
Any ideas how could I fix this issue? Is it matter MyRIO is connected via USB or WiFi?
05-04-2015 04:01 PM
What camera are you using? Only certain cameras can be used with the myRIO, and that may be the case here. Section 2 of this document gives a bit more detail.
05-05-2015 03:46 AM
I found my camera on the list from your link. I am quite sure that I have a marked camera so it should work according to the list (attachment).
