11-08-2009 03:20 PM
OK so I'm shamelessly seeking sympathy.
Large project was behind schedule- contractor that was hired to do the work wasn't up to the task. And here I am looking at a project that is "Insane" on my Sunday off. About 100 VIs and ctls that are jammed in a structure that has no possibility of controlling state flow if a hardware (operator) error occurs. ReVIse......
11-08-2009 04:11 PM
During an interview for my current job I was shown two ATEs that were collecting dust because the vendors weren't "up to the task". I should have seen it coming, but I was assigned to complete both of them. I'm currently on a third clean-up project.
Here's an article that says rewriting code from scratch is the "single worst strategic mistake that any software company can make." I'm going to guess that this doesn't include code that doesn't work or has a horrible architecture. I put the first project into production without rewriting it, but saw then that any future mods would be horribly difficult. I've since rewritten it and the other two. Perhaps you're in the same boat?
Good luck!
11-09-2009 02:11 AM
jcarmody
your current icon Ford-Perfect-ly fit:-)
"Funny, how just when you think life can't possibly get any worse it suddently does" Mavin, THGTTG
11-09-2009 05:52 AM
11-09-2009 07:23 AM
jcarmody wrote:During an interview for my current job I was shown two ATEs that were collecting dust because the vendors weren't "up to the task". I should have seen it coming, but I was assigned to complete both of them. I'm currently on a third clean-up project.
Good luck!
G-Story:
I was contracted to re-write an app that was failing misreably. Durring my presentation of the new architecture (prior to coding) to the in-house team one of the members noted "Ben, it looks like you are going to completely re-write the app, WHY?" I responded, "The issue with the other application are mostly due to a poor design that sucked. I plan on writing correctly." They did not expect that answer but it was the truth. So after re-writing it based on five sperate threads, instead of one (how can you keep a PID under control if your code is single threaded and spends all of its time trying to auto-scale a curve-tracer and only after wards finds the PID has wondered off to lala-land), they asked to have the app as three diferent flavors.
So writing a program do do what another one failed to do is not rew-riting it, since the first version was not a reality.
Ben
11-09-2009 09:35 AM
Jim-
OH I'm in that boat alright- Anyone got an oar?
Thanks for the support - Ben- Not surprisingly those are the exact words I just used to explain to the department why I need time to "Redefine basic test factors to meet internal standards of test design."
11-09-2009 02:45 PM
We had a contract programming house build an app for us. It worked perfectly (if a little slow). It didn't turn into a nightmare until we had to modify something. A couple of years down the road - there *MAY* be one wire left over from the original code. It also runs a lot faster now. We haven't contracted out code since.
In a previous job, I confronted one of the engineers who had built his own LV code to do some testing on his hardware. His reply to me, "It works, so get lost." A few weeks later I delivered his newest test system (I was in charge of the lab) as a mass of wires around the components (looked like a plate of spaghetti) and told him, "It works, so deal with it." Good thing I had a boss that backed me up.
Rob
11-09-2009 03:49 PM
I personally even would go (and I do, with all consequnces) for rearchitecting some code if it ran out of scope (simple example: if there is a huge set of case structures that evolved over time, go for a state machine). But if you do so, try to keep the SubVi code untouched (it might be a mess of math, but it worked before) in order to make small changes on the overall code (it is like keeping a valid build all the time). And account for this coding on the schedule (rearchitecting takes severe time).
One more point for the rewriting side: in TDD (test driven developement), they considere it a practice, that if your code fails the test, it is cheaper to rewrite it than to debug it.
But: try to keep the overall cahnge managable. That means, if you do a new architecture, practice it first on a smaller project before getting wild on the big one. An: try to have a valid build all the time. For a certain set of SubVIs, a regression testing might be useful as well.
Felix
11-09-2009 04:00 PM
I have re-written a number of applications because a: they sucked, and b: the operators wanted new functions and features in the "upgraded" code. It might as well have been a brand new application, deserving of a re-write from scratch.
11-12-2009 08:27 AM - edited 11-12-2009 08:28 AM
F. Schubert wrote:Here's an article that says rewriting code from scratch is the "single worst strategic mistake that any software company can make."
True Story:
Employee 1291: "Can you please modify this Vi so that the switches stop getting stuck or flicker real fast for no reason"?
Me: "No I can not".
