BreakPoint
Monthly Bugs, October 2008
Message 21 of 32
(7,743 Views)
smercurio_fc wrote:
aartjan wrote:
A new type of error while Labview crashes.
http://forums.ni.com/ni/board/message?board.id=170&message.id=357011&jump=true#M357011
Aart-Jan
Please note that this thread is to report confirmed bugs, not errors which as of yet have not been confirmed to be actual bugs with LabVIEW. As I noted in my response in that thread, do you have a CAR?
CAR #128520
Message 22 of 32
(7,737 Views)
see here for more details.
R&D (#130294 CAR ID)
Message 23 of 32
(7,723 Views)
The "Use Default Limits" text in the properties dialog appears garbled in 8.6 -
http://forums.ni.com/ni/board/message?board.id=170&thread.id=363628
___________________
Try to take over the world!
Message 24 of 32
(7,704 Views)
When a library (.lvlib) that contains a file with a run-time-menu (.rtm) file is removed from the project, but there is still a file that uses this .rtm file, both the .lvlib and all of it's vis and the .rtm file are displayed in the project Dependencies.
For the Vi's the callers can be found by 'Find->calllers'. For the .rtm file this always results in 'No items found' but the .rtm file remains in the Dependencies (as it should since it is still used).
Finding the .rtm file can be hard since it is only loaded at run-time and not at edit time(?). If someone encounters this issue, a working method:
- rename the rtm file (so it cannot be found)
- open the vis that you suspect are using this file AND try to edit the run-time menu. When this vi uses the run-time menu a warning will appear (cannot load rtm file, using default menu instead)
Kind regards,
Mark
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
Message 25 of 32
(7,683 Views)
Has this been identified as a bug?  Please read the format for the bug thread posted here.  Please post a link to the message thread where all this is discussed.
Message 26 of 32
(7,678 Views)
When images are placed in the report these are generated in the temp folder. When the report is disposed, these files are not deleted. This will cause the temp folder to fill. I have modified my dispose report.vi file in vi.lib to solve this problem.
http://forums.ni.com/ni/board/message?board.id=170&message.id=364647
Message 27 of 32
(7,622 Views)
The append control image uses a millisecond timestamp to create a unique filename. When this function is called more then once in a millisecond the unqiue naam is not unique. Again, i have modified my dispose report.vi file in vi.lib to solve this problem.
Message 28 of 32
(7,622 Views)
Message 29 of 32
(7,570 Views)
Can't index parts of VRML model with Object.Get Object
CAR # 125788
Message 30 of 32
(7,513 Views)
