11-01-2006 10:46 AM
Rules:
11-02-2006 08:15 AM
Apparent re-occurrence of LabVIEW Floating Window problem within TestStand.
http://forums.ni.com/ni/board/message?board.id=330&message.id=13149
11-03-2006 01:57 PM
11-07-2006 08:29 AM
11-07-2006 08:32 AM
11-07-2006 10:51 AM
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=213981&jump=true
Aristos Queue ID's ab ug in the way the "Syncronous" setting interacts with the "Erase First" setting for a picture control.
CAR# = (# 43699OJ1)
Ben
11-07-2006 11:31 AM
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=214212&jump=true
Allison reports CAR# 3R1F8KRJ
I am not sure what the bug is,
  but it does have a CAR.
Ben
11-07-2006 02:32 PM
Hierarchy screen forgets settings!
In previous version of LV you set it once and forget it. Now you have to set it each time you open the hierarchy screen.
I concider this an "ease of use" bug.
See this thread.
http://forums.ni.com/ni/board/message?board.id=170&message.id=214276&a#M214276
Ben
11-07-2006 03:47 PM
11-09-2006 03:01 PM
Jeff Peters of LV R&D indicated that the up/down arrows on an enum can be misleading.
http://forums.ni.com/ni/board/message?board.id=170&message.id=214718&jump=true
Not sure if this is a bug but it can be confusing.
Temporary work-around is to customize control and swpa up/down button postisions and then swap their images.
Ben
