BreakPoint
Monthly Bugs (September 2006)
This is the continuation of the August Bugs Thread
Rules:
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Chilly Charly    (aka CC)
Message 1 of 23
(9,964 Views)
As discussed here, The "Show constant folding" new option of LV 8.20 is buggy.
Message 2 of 23
(9,954 Views)
Please see the third message in this thread for a Mac-specific bug, regarding the array-to-cluster function.
http://forums.ni.com/ni/board/message?board.id=170&message.id=203583
---Peter H.
Message 3 of 23
(9,945 Views)
hi there
LV 8.0: there seems to be a bug in the Text File IO functions. Incomming errors set the refnum to NULL.
Topic is discussed here: http://forums.ni.com/ni/board/message?board.id=170&message.id=204042&jump=true
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 4 of 23
(9,886 Views)
No thread for this, just some weird behaviour I noticed after upgrading to 8.2
When resizing text using the <ctrl> and +, there's a small display bug.  Added 'junk' goes away with scrolling.
See image
Message Edited by Day on 09-08-2006 01:36 PM
Message 5 of 23
(9,842 Views)
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=204785&jump=true
Kennon confirms that if you are using a custom run-time menu in an exe, "ctrl-E" is not available so you can not debug an executable.
He also offers some advice on how to deal with the complication.
Ben
Message 6 of 23
(9,789 Views)
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=204543
NathanT confirms that there is a (minor) bug in the linking of type defs inside datalog file refnum controls (fixed in LV 8.2)
Jaegen
Message 7 of 23
(9,784 Views)
This is probably more of a "limitation" than a "bug", but in this thread:
Jarrod S confirms that there is no way of using the "latch" mechanical actions on a boolean control inside an XControl, without additional code outside the XControl.  There is no way internal to the XControl of forcing the Facade VI to run again in order to reset the output value, so even though the button on the Facade VI instance resets after it's read, the "Data Changed?" value isn't updated, and the reset value doesn't get sent out to the parent VI.
Jaegen
Message 8 of 23
(9,778 Views)
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=205315#M205315
Roy F confirms that LV will not (without help) utilize more than four proccessors.
He confirms that using the "threadconfig.vi" utility will correct that situation.
A CAR has been filed to investigate.
Ben
Message 9 of 23
(9,730 Views)
On the LAVA forum in this thread
http://forums.lavag.org/index.php?showtopic=4098&pid=16564&st=0&#entry16564
David Boyd reports a problem customizing the scroll bar size for a table.
See that thread for more information.
Confirmed in LV 8.0 and LV 8.20
Ben
PS NO I will not repost his message to the NI Forum. Smiley Wink
Message 10 of 23
(9,733 Views)
