BreakPoint
Monthly Bugs (December 2005)
This is the continuation of the November 2005 monthly bug thread.
Rules:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
  • Message 1 of 9
    (8,173 Views)
    In this thread, it is demonstrated that the Sine function returns illegal values (outside +/-1) for huge inputs. It returns the input unchanged instead. This is unexpected
    Message 2 of 9
    (8,118 Views)
    There appears to be issues with with the wrong combination of unbundles, bundles and replace array subset.
    http://forums.ni.com/ni/board/message?board.id=170&message.id=157212
    Since a an unbundle by name seems does not crash LV this may be an issue with the unbundle function. See that thread for more info.
    Ben
    Message 3 of 9
    (8,079 Views)
    Formula node fails certain U32 operations under LabVIEW 7.1.
    (Apparently fixed in LabVIEW 8.0 ;))
    Message 4 of 9
    (8,064 Views)
    LV 8.0 : The vi background color is not preserved when printing or exporting to a picture, as exposed here
    Chilly Charly    (aka CC)
    Message 5 of 9
    (8,026 Views)
    LV 8.0 : The table cell size can't be decreased under 5 pixels, while it was possible to go down to 2 pixels in previous versions
    Message 6 of 9
    (8,020 Views)
    Existing good wires to a mathscript node seem to get broken for no reason at all:
    (I cannot reproduce this from scratch, but the VI shown clearly has some weird corruption).
    Message 7 of 9
    (7,993 Views)
    Squeeze in one more to end the year right. (or would it be wrong?)
    The Match Pattern function is missing from the LV8 PDA String palette.
    http://forums.ni.com/ni/board/message?board.id=170&message.id=158422
    Ed
    Ed Dickens - Certified LabVIEW Architect
    Lockheed Martin Space
    Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
    Message 8 of 9
    (7,942 Views)
    his concludes the Decmeber 2005 bug thread. Please continue in the January 2006 version 🙂
    Message 9 of 9
    (7,908 Views)
