Lookout
Why demobox for lookout basics is not communication?
(3,921 Views)
Do you get any alarms?  If yes, what do they say?
-Khalid
(3,919 Views)
In the alarms window: No communication response from modbus secondary.
(3,907 Views)
Are you using the default settings for the Modbus object?  Also make sure that the serial cable is a straight one (as opposed to a null-modem one).
-Khalid
(3,899 Views)
yes using the default settings for the Modbus object
(3,893 Views)
Are you using a staright-through serial cable?  Can you verify that the COM port itself is functioning correctly.  You can do this by doing the "loopback" test:
http://zone.ni.com/devzone/conceptd.nsf/webmain/D48BA43C59B60277862569EE000501FD?opendocument
Hope this helps,
-Khalid
(3,881 Views)
