10-22-2007 10:25 AM - edited 10-22-2007 10:25 AM
Message Edited by Anthony de Vries on 10-22-2007 05:27 PM
10-22-2007 10:33 AM
10-22-2007 02:34 PM
@Anthony de Vries wrote:
I don't know exactly when this happened. Presumably during the upgrade, but I'm not sure.
I think there is something wrong with this express VI in 8.5 in general, does not seem to be an upgrade issue. The connectors get screwed up even if I place a new such express VI and then change the style to subVI.
Does it work properly if you display it as express VI instead of a subVI? (right-click...icon style).
10-23-2007 03:53 AM
10-23-2007 09:08 AM
@Anthony de Vries wrote:You're right, this behaviour seems to occur all the time. I'll write a bug report about it.The other problem is that when the input is integer, the output also limits to integer. Which is what screwed up the calculation. It didn't use to do that.Works again when I put a DBL conversion into one of the inputs.
10-23-2007 11:06 AM
10-23-2007 11:38 AM
Of course I just recently discovered the rather undocumented (?) 8.5 feature of output coercion (psst?), so maybe we'll have more control over all of this down the road.
10-23-2007 11:40 AM
Existing instances of the Formula Express VI should load and still use the DDT, thereby producing exactly the same result as they used to.
10-23-2007 11:41 AM
10-23-2007 12:50 PM
