07-02-2005 06:11 PM
Wow, John, that is great. 5 stars to you.
For those who missed it, if you write the local path to image file, the image gets incorporated into the message! You can probably do that with multiple images as well.
Molly, is there any way to place a browse button to the local hard drive, instead of saying "You must be hosting the picture and supply a URL"?
07-02-2005 06:43 PM
Whoa, whoa, whoa.
STOP!
After examining the HTML code generated, and playing around, I found out that writing a local URL causes the image to appear only when browsing from your computer, and only as long as it's where you left it. Basically, the browser just uses the address you gave it as a URL. So, no 5 stars, John, sorry, we still have to upload images.
07-04-2005 01:23 AM
OK, this really sucks:
When attaching a hyperlink there is no option for inserting a display text.
If I try to use the macro I have, which places the HTML code directly in the post, nothing appears in the edit field,
and if I try to type the HTML code directly into the post, it is not interpreted as HTML, so the link doesn't work.
07-04-2005 10:07 AM
That stumped me too.When attaching a hyperlink there is no option for inserting a display text.
07-04-2005 12:42 PM
Thanks, Ed.
That's good to know, but it's still a terrible workaround. There should be a field for text when adding the URL.
It seems that when I post a macro that has a lot of text the links turn out fine (maybe because the address is already in the HTML code when I insert it), but when I inserted one with the empty <a href=""></a> nothing appeared. I guess that's because the editor "compiles" the HTML immediately. I'm assuming that's what's needed to show stylized text in the editor.
07-06-2005 10:28 AM
@tst wrote:
Whoa, whoa, whoa.
STOP!
07-06-2005 12:16 PM
Molly, et al,
Check this out! Latest "interesting" behavior that I will ascribe to our new editor:
http://forums.ni.com/ni/board/message?board.id=170&message.id=128705
Check the last few posts. I'm really not trying to inflate my numbers!!!
P.M.
07-06-2005 01:13 PM
LV_Pro -
I saw a similar problem with a new question being posted repeatedly this morning. Thanks for letting me know. I have reported it and hope to have quick resolution.
Thanks!
07-13-2005 04:58 AM
A couple of additional comments:
OK, now it seems that sometimes the buttons do load from the cache and that the page is displayed fully without wait. The only problem is that when this happens, I can't write. I have to click refresh and wait for the graphics to reload before I get the cursor.
When this happens, or if I wait for the cursor to appear, clicking Quote Post causes the quoted post to appear immediately at the top of the page (look at the attachment). Clicking multiple times causes the quote to appear multiple times.
07-13-2005 06:22 AM
