Twitter Toolkit for LabVIEW
GPIB error (error 0) when I try to run a simple program
Arend-Jan van Hilten Sep 2, 2014 9:25 AM
I get a GPIB error (error 0) when I try to run a simple program. The Twitter Open.vi gives no error, but the subvi after that gives. I'm using LabVIEW 2014.
Arend-Jan
Hi Arend-Jan,
Unfortunately all the VIs in the toolkit tend to return error code zero when an error occurs which was very bad programming practice on my part. Sorry about that. However they do tend to include more information in the path string describing what went wrong.
You mentioned that you are running a simple program but do you get a similiar problem when running one of the example programs? There should be an example based on the different task you are doing.
Milan
Milan
(19,570 Views)
Hi Milan,
Open the twitter and than tweet something, and that gives me the error.
Thank you,
Arend-Jan
(16,036 Views)
Hi Arend-Jan,
It looks like you may have an older version of the i3 Twitter Toolkit. Can you upgrade it by installing the latest version as described on the Installing the Twitter Toolkit VI Package page.
After upgrading the toolkit, use the example titled Post New Tweet - Finite.
Milan
Milan
(16,036 Views)
Hi Milan,
After installing the twiitter toolkit I am getting again error 0. I'am using the Labview 2014 64 bit edition on a windows 8 pc, maybe it's because of that.
I really appreciate your help.
Arend-Jan
(16,036 Views)
Hi Milan,
My father(Erik van Hilten) just looked at the code and it gave an error at the HTTP error vi, error 220 which stands for wrong credentials or something. Then I changed the input of the shift register, and after some wrong tokens it works. The consumer key and secret(according to the code) are described on dev.twitter.com as API keys. The Access Credentials(according to LV, Shift register) are described as access token and access token secret on the twitter site. so the GPIB error isn't something with the GPIB driver, would have been weird, Twitter via a GPIB cable, but it is something with the wrong tokens.
Thank you for your help,
Groetjes from the Netherlands,
15 yo
Pi-nerd.comze.com
(16,036 Views)
Hi Milan,
I would like to share my code, so everybody can test the code on their computer and the tweak the code.
Post tweet anonymuis account.vi
Groetjes,
Arend-Jan
PS: It is answered and it was my fault
(16,036 Views)
Hi Arend-Jan,
I am glad you were able to figure out the problem! Yea, it is confusing having the terminology different from the Twitter website and the i3 Twitter toolkit. I will try and clarify the tokens in the documentation in the future.
Also, like you saw, the error messages I used were very confusing. Twitter via a GPIB would be a weird idea
Good luck with your project and I hope it is going well!
Milan
Milan
(16,036 Views)
