LabVIEW Interface for Arduino Discussions
LIFA Problem with pins Arduino UNO
Good evening friends, I have a computer with windows 7 x64, labview 2013, arduino IDE 1.0.5, VISA 5.4.1, an Arduino UNO board, I have a problem when I upload LIFA_Base.ino to the card, some digital pins instantly turn ON state, this happens to me in pins: 13,11,10,9,6,5,4,3 but in pins 12,8,7,2 does not happen, how can I fix that?
(7,559 Views)
Accepted by topic author kanuto
I suggest you bypass this problem by upgrading to LINX.   LINX is a replacement for LIFA.  I made a quick check.  After uploading LIFA digital pins 3, 4, 5 were on.  After uploading LINX digital pins 3, 4 and 5 were off.
Near the top of the Discussions page there is an announcement about LINX.  The announcement contains a link to a Getting Started with LINX Tutorial.
hrh1818
(5,814 Views)
Thank you very much for the info, I'll try, greetings.
(5,814 Views)
Hello
Could you please help me ?
Where can I find LINX tutorial for Arduino ?
(5,814 Views)
You should probably post your questions to the LINX forums. If you have installed LINX just go to Help>>Find Examples... and type LINX in the search tab.
Now Using LabVIEW 2019SP1 and TestStand 2019
(5,814 Views)
Just like with LIFA there is no Using LINX tutorial.  The developers of LINX expect you to learn how to use LINX by studying the examples.
hrh1818
(5,814 Views)
I tried LINX and I dont have the problem anymore, thanks hrh1818..!!
(5,814 Views)
