Question 1) Which of the following Block Diagrams could produce this result in Waveform Graph?
Question 2) Which of the following will allow you to have multiple plots on a Waveform Graph?
A) Bundle two 1D arrays of X and Y data together for each plot. Then build an array of these clusters and wire it to the Waveform Graph indicator.
B) Build an n-dimensional array of data with each plot in a separate row (or column) in the array, then wire the array to the Waveform Graph indicator.
C) Bundle the elements of each waveform into a cluster and build an array of these clusters, then wire the array to the Waveform Graph indicator.
D) Both B. and C.
E) Both A. and C.
Leave your answers as comments below by clicking on Reply
You will need to be logged-in to do so. Click here to sign-in/sign-up.
Rules & Guidelines
Recordings of the Previous Sessions
