 SANDRALO
			SANDRALO
			09-05-2010 11:11 PM
There are 2 switches FS and GS on the NI USB-6229 data logger but I don't know which one I switch when using it??
		09-07-2010
		06:32 PM
 - last edited on
		06-25-2024
		02:47 PM
 by
		 Content Cleaner
			Content Cleaner
Howdy SANDRALO!
FS = Floating Source
GS = Ground Referenced Source
If the source you are trying to measure is floating (such as a battery) then you will want to use the FS setting. If you source you are trying to measure is referenced to ground then you will use the GS setting.
The Field Wiring and Noise Considerations guide is a good resource for information about grounding.
 ck.x
			ck.x
			09-08-2010 10:52 AM
Hey SANDRALO!
Also, if you have any other specific questions about this board or other DAQ boards, there is an entire forum dedicated just for that:
Cheers!
