VirtualBench
measure phase
I own a VB-8034. I would like to know if it is possible to measure the phase difference between 2 signals?
(4,316 Views)
Hi LabMIQ,
In the application, this can only be done by hand because it doesn't have any two-channel measurements. You can use single-channel measurements to find and highlight the maximum/minimum, and then use the track cursors to measure the time difference. Add a period measurement, and you can calculate the phase difference.
This approach can also be taken with the API: find the time coordinates of the same reference point in the waveforms, measure the period, and calculate the phase difference.
124 us / 500 us = 0.248 = 89.3deg
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(4,303 Views)
Hi JoeFriedchicken,
Thanks for your answer but it's a shame that it is not incorporated into the software...
(4,301 Views)
