VirtualBench
fgen initialization on external Trigger
For the NI_Virtual Bench with the external trigger BNC, Can we trigger the Function generator to start the square wave ? I mean, i want to produce the trigger so i have the start of the square wave
(8,282 Views)
Accepted by topic author yeshwanth
You cannot trigger the function generator to start in response to an external signal.
However, you can export a signal that pulses when the FGEN starts to the external trigger BNC. You can do this with the "Dig Export Signal" entry point.
William Earle
NI R&D
(8,274 Views)
Example Please!I just need this function.
(8,221 Views)
You configure it through the Digital Instrument.  Here it is in the VirtualBench application:
Here it is in the LabVIEW API:
Zach Hindes
NI R&D
(8,199 Views)
Thanks ,will the fgen support external Trigger through Firmware update?
(8,012 Views)
No, there are no current plans for the function generator to support a start trigger.
Zach Hindes
NI R&D
(7,997 Views)
