VirtualBench
VirtualBench Pinout for 783540-01 MSO Logic Analyzer 40 Pin IDC to Mictor Cable, 0.5m
Can anyone direct me to or supply the Mictor pinout for this 783540-01 cable?
(5,432 Views)
Accepted by topic author SansPants
The easiest solution I could find was just to copy this over from my notes.
VirtualBench MICTOR Cable Pin MapVirtualBench MICTOR Cable Pin Map
Daniel Larsen
Digital Hardware Engineer
(5,420 Views)
Thanks for the reply SiMylo,
Can you confirm the pin numbering matches the TE Connectivity datasheet, odd numbered pins on one side evens on the other like this:
TE Mictor DrawingTE Mictor Drawing
I assumed this at first, but the organization of your table raised the question.
Thanks again.
SansPants
(5,401 Views)
SansPants,
Yeah, I see that the chart would be cleaner if it had been organized with odd pins on one side and even pins on the other - that's just what I had in my notes.  You are correct, the 'MICTOR PIN' column refers to the physical pin on that connector as shown.
Daniel Larsen
(5,393 Views)
