VirtualBench
VirtualBench API does not have scope measurements
Hi
Why is virtual bench API is not having scope measurements?
"The VirtualBench API does not have scope measurements because LabVIEW has a waveform measurements palette "
... is not a sufficient explanation for me because
--> the measured values are still some where generated inside the box (can be seen with GUI)
--> Many people would like to use the VB also without Labview but with C or Python.
Please fix/add this obviously missed feature in API.
BR,
Stefan
(6,328 Views)
Please post your feature request or suggestions in the ideas Network.
https://forums.ni.com/t5/Idea-Exchange/ct-p/ideas
Best wishes
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(6,302 Views)
So the measurements are only calculated with methodes implemented in the VB GUI and not inside of the VB, right?
(6,248 Views)
Correct, the VB is only the meaurement device, all calculations are made on the Host.
(6,246 Views)
is there an API of the VB GUI for control or/and get values?
BR
Stefan
(6,244 Views)
There is the VB API that is also used by the GUI.
This is the API to use to communicate with the VB.
(6,242 Views)
