VirtualBench
VB python control errors
I am using a NI module supplied with the virtual bench to try to control the power through python. I use the code beneath, but I get the error:
Error/Warning -375905 occurred
NI-VirtualBench: Invalid channel name.
Configuration: Power Supply Channel
Requested Value: 獰⬯㔲V㔈౻
Allowed Values: ps/+6V, ps/+25V, ps/-25V
I am using the example's channel name, and the requested value in the error does not relate to it as far as I can tell.
Has anyone come across this before or know a solution?
Thanks a lot,
Matt
from pyvirtualbench import PyVirtualBench, PyVirtualBenchException, Waveform
try:
# Power Supply Configuration
channel = "ps/+25V"
voltage_level = 24.0
current_limit = 0.5
virtualbench = PyVirtualBench('VB8012-31373F7')
ps = virtualbench.acquire_power_supply()
ps.configure_voltage_output(channel, voltage_level, current_limit)
ps.enable_all_outputs(True)
# for i in range(10):
# voltage_measurement, current_measurement, ps_state = ps.read_output(channel)
# print("Measurement [%d]: %f V\t%f A\t(%s)" % (i, voltage_measurement, current_measurement, str(ps_state)))
ps.release()
except PyVirtualBenchException as e:
print("Error/Warning %d occurred\n%s" % (e.status, e))
finally:
virtualbench.release()
(6,610 Views)
Matt,
Which version of python are you using (python2 or python3)?  If you're using python3, I think I may see the issue because it's something I've run into personally when migrating from python2 to python3.  The underlying C API is expecting a traditional C string (char *) data type, but in python3, 'all strings are sequences of Unicode characters' (which is a fancy way of saying it doesn't use the same encoding).  You can read more about the string datatype in python3 http://www.diveintopython3.net/strings.html .
If my theory is correct here, you should be able to fix this error by changing the assignment to
channel = "ps/+25V".encode('ascii')
Daniel Larsen
Digital Hardware Engineer
(6,591 Views)
Hi Daniel,
Thanks for the help. Sadly im using python2.7 for this, and using an ascii encoding didnt help, still the same error.
Would it be better to try it in python3 do you think?
Matthew
(6,586 Views)
Sorry to hear your issue isn't resolved yet, though I still suspect it's a string encoding issue.  Now that I look closer, this page actually specifies that you should be using python >= 3.4, so switching might just work around the problem.
https://github.com/armstrap/armstrap-pyvirtualbench/blob/master/README.md .
Daniel Larsen
(6,578 Views)
I installed 3.4 and tried that, but still the same error sadly. I will try to automate it with Labview I think.
(6,504 Views)
