04-23-2026 02:31 PM
I have 17 VIs from a LabVIEW 2011 (v11.0) project that I need converted to LabVIEW 2026. These VIs are part of a sensor test system (Infineon EMAG tester).
When I try to open them in LabVIEW 2026 Community Edition, the COM API returns error 0x423 ("Unexpected file type") and Mass Compile fails with "error 42 / Failed to load." The VIs were last saved in LabVIEW 11.0 format within an LV2011 project.
Could someone please mass compile these into a version that LV2026 can open? (e.g., mass compile in LV2014 or any intermediate version)
The ZIP preserves the original folder structure (DAQ, File IO, Globals, GUI, password, Utilities). These VIs have sub-VI dependencies that are NOT included — I only need the 17 files themselves recompiled/resaved so I can open them in LV2026 to view the block diagrams.
Thank you!
04-23-2026 07:02 PM
Unfortunately, I think these VIs have been corrupted. I couldn't even open them with 2016 (my next oldest I have installed is 8.2). Is there a backup you could get the code from? Hopefully in a Source Code Control (SCC) system such as SVN or Git.
04-24-2026 08:45 AM
i can try and extract them from the windows xp drive but this maybe difficult. Thanks for trying, i will resubmit if i can get the files off the original drive.
