VeriStand
how to create a .dll from a simulink model .mdl file to use on veristand
Can anyone Help me with converting .mdl to .dll .
Its the same Compiler Problem which HARIKA had. (Message 5 and 6)
Just explain how can i install a new VC++ complier for my Matlab ?
AAK.
Message 21 of 24
(3,463 Views)
Hi A.A.K.
Make sure you have the right Matlab and Simulink version installed, like stated in
http://digital.ni.com/public.nsf/allkb/2AE33E926BF2CDF2862579880079D751. And make sure you have the 32 bit version of Matlab and Simulink.
Afterwards just download one of the compatible VC++ compilers which are also listed in the link above. For Vistual Studio 2008 you can use following link, http://www.microsoft.com/visualstudio/en-us/products/2008-editions/express.
Then you have to use the mex comand in Matlab and choose the wanted compiler.
Message 22 of 24
(3,458 Views)
Your links are not opening. But i think i have checked those already.
I am in discussion with few NI guys on the following link
http://forums.ni.com/t5/LabVIEW/3-level-PWM-inverter/m-p/2098460#M684221
Kindly have a look and see if you could help me.  (Message 13 onwards)
Regds,
AAK.
Message 23 of 24
(3,454 Views)
Well done Luk04 🙂 and dp pardon the inconvenience.
- I've identified the MATLAB support installation issue. This appears to be specifically with versions R2010b and later. This issue is documented under CAR 362884.
Nestor
Message 24 of 24
(3,446 Views)
