VeriStand
Workspace : Numeric control/Indicator format not saved
Using VS 2013, I'm not able to maintain numeric format of a Medium Numeric.
Numeric Format Setting
  • Open and run the example project Sinewave Delay
  • On the workspace, right-click on a numeric indicator to open the Edit Item dialog box
  • Go to the Format & Precision tab, set Format to an other value that Decimal (Engineering here), click OK.
  • Save (File » Save) and Exit the Workspace
  • Run again the project
  • Go to the Format & Precision tab : Format value is Decimal (not the previously set value)
I don't believe that's the expected behavior (also tested with VS2012). This is also true for Controls.
Did I make something wrong? Is this a bug? Am I the only one to have this issue?
(6,791 Views)
Accepted by topic author Mathieu_R.
Hey Matheiu,
This is definitely a bug. It should not function that way.
We have the issue tracked internally as CAR#449833. Keep an eye out for that number in the Bug Fix section of upcoming patch/version releases readme's (similar to this). We should hopefully get it addressed soon!
Tim A.
(6,745 Views)
(6,730 Views)
Sounds good! (Yep, SP1)
Tim A.
(6,728 Views)
