VeriStand
VeriStand2021 vsmodel import error
When I import vsmodel to Veristand2021, there is an error, I can't go on, could some help?
I have veristand2021,labview 2021x64, matlab2021b with veristand model generate tool add-on installed.
Here is the error information and the vsmodel and the simulink model.
(5,614 Views)
I'm betting that posters more familiar with Veristand will monitor the specific board more closely. I'll move the thread and leave a unexpiring placeholder.
"Should be" isn't "Is" -Jay
(5,590 Views)
Hi Harvey_He,
From my understanding, VeriStand 2021 does not support models from The MathWorks, Inc. software version R2021B. I would recommend using an older version of The MathWorks, Inc. software to build the models for TestStand. Compatibility can be found here: https://www.ni.com/en-us/support/documentation/compatibility/17/veristand-version-compatibility.html
Andy
Senior Solutions Engineer
NI
(5,578 Views)
Accepted by topic author Harvey_He
Hi Harvey_He,
I responded to your other post, but I will clarify here. You can add vsmodels to VeriStand 2021 via the Mapping Diagram. The new VeriStand Model Generation Support toolbox supports 2020a-2021b as described in the documentation. We are working on updating the VeriStand Model Version Compatibility document to reflect the new toolbox (.vsmodels).
tic.not.tock is correct that the Model Framework does not support 2021a/b. VeriStand 2021 supports both the Model Framework and the new VeriStand Model Generation Support Toolbox (.vsmodels) as there are still some limitations in the new support that we are working to address. For more information on the current limitations, please refer to the Toolbox documentation.
Brian.D
NI Product Owner
VeriStand
(5,558 Views)
Dear Brian.D,
I got your message, and solve the issue, many thanks to you.
(5,470 Views)
