10-06-2017 07:14 AM
My model can not be deployed. I add the error message and simulink model as an attachment. Any suggestions?
10-06-2017 12:57 PM - edited 10-06-2017 12:57 PM
Are you certain that your model is the culprit? If you try deploying your system with the model removed from the system definition do you still see the same deployment failure?
10-10-2017 01:49 AM
I have just tried it out. Unfortunately it doesn't give me the same failure. When there is no model in system definition, It says the model may be deleted. Any further suggestions?
