VeriStand
VeriStand 2016: Simulink Model will not be deployed: Error 307672
My model can not be deployed. I add the error message and simulink model as an attachment. Any suggestions?
(2,662 Views)
Are you certain that your model is the culprit? If you try deploying your system with the model removed from the system definition do you still see the same deployment failure?
(2,641 Views)
I have just tried it out. Unfortunately it doesn't give me the same failure. When there is no model in system definition, It says the model may be deleted. Any further suggestions?
(2,631 Views)
