VeriStand
Stimulus Profile command shell
i have to create a Stimulus Profile in order to do measurements on my testbench. This should function with NI VeriStand Stimulus Profile Editor. Because of doing some changes in the system i have to set different values in the Program CANoe from Vector. I have managed it yet, that the program starts via command shell in the Stimulus Profile. Now it should be possible to run the configuration in CANoe and to set different values. How could i handle this and comparable problems? Should i search for other solutions or does it work with the command shell? I have read that VeriStand is compatible with the programming language C, is maybe there a way to solve the problem?
Thank you!
Message 1 of 1
(2,360 Views)
