VeriStand
Set NodePath NodebrowserWF
I'm using the NodeBrwoserWF Object to select channels in my VeriStand Custome Workspace object. Once I select a channel, I catch the Node path and save this into a file. When I close the project and re-open it, I want to set the node path again to the node brwoser. I've seen I'm not able to switch the BaseNodeType-->NodePath to "Write".
Is there any function to set a givven channel path (string) to the NodeBrowserWF Type?
Christian
(3,561 Views)
Hi there,
The proper way to access and set the node value for the NodeBrowser is that one:
- http://www.ni.com/example/31266/en/
Of course, you can skip some parts of that example if you know the path of the node you want to use.
--Eric
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(3,524 Views)
I'm facing a similar problem: Trying to set the node value in the NodeBrowser.
Unfortunately, the link Eric provided nolonger works.
Can someone point me in the right direction?
(2,602 Views)
