VeriStand
PXI-8512/2 XNET CAN stops when bus errors occur on RT system
Hi, This is when I launch the workspace (with the PC as target). The conditional disable continues to work with my other devices.
18707i3F6BA95D281E8DB4
Message 11 of 15
(4,236 Views)
Hi hyog,
I am able to reproduce the issue. I am currently looking into work arounds.
Joshua B.
Message 12 of 15
(4,218 Views)
Hi DiscoBall,
Please let me know if you have been able to find a workaround for the error when running in PC Simulation Mode. Thank you.
Message 13 of 15
(4,147 Views)
Hi hyog,
We are still looking into this...sorry for the delay.
Joshua B.
Message 14 of 15
(4,135 Views)
Error -1074384758:
    I am using NI-PXI for setting up a hardware in the loop test on a CAN bus. One PXI-8464 card for CAN communication is installed on PXI box. My model can be deployed when I am not adding any NI-XNet communication channel to my model. However when I add a CAN channel and run the system following error message comes up. Would you please help to deal with this problem?
Amir
Message 15 of 15
(3,639 Views)
