VeriStand
Veristand Randomly wont play stimulus profile?
I have run this profile many times before... I go to compile it, I get no errors. I run it, nothing happens. I don't see the green bar proceed line by line, I don't see a results page. The "Execution Results" say "Not Executed" and "Passed"
Any hints as to why this might be happening? System is deployed, I tried rebooting the PXI system and my desktop.. to no avail.
Sometimes if I restart the stimulus editor it will run once or twice... and then stop again.
(7,145 Views)
Do you mind to upload the profile and all custom rt sequences that are being used?
If you don't want to upload it, I think it is possible to send them in a private message as well.
Tom
(7,139 Views)
I prefer not to. Can you just tell me the diagnosis procedure you would use? For the benefit of others as well?
(7,138 Views)
It is suspicious that is runs sometimes but not other times. I would check if all expression are correct (especially variable names) since there was the one or other issue in 2011.
Other than that, i would suggest to try to use the .net API directly to see if that returns a more meaningful error on deployment or possibly shows a different behavior.
(7,133 Views)
can you be more specific about the 'one or other issue'? Perhaps i'm experiencing that.
(7,124 Views)
scratch that.
(7,106 Views)
