VeriStand
Model Rate
I have a problem with model rate on a PXI 8109 RT controller.
I'm running only one model, made with simulink and compiled with real time workshop.
Whatever step size I select from real time workshop, I see the correct model rate from the Veristand "add simulation model" window, but when I actually add the model, I always see 100Hz as model rate in the model information window.
What am I missing?
Matteo
(6,681 Views)
Accepted by Matteo_Orciari
Hi Matteo,
This is a know issue with NI VeriStand 2011 that should be fixed in NI VeriStand 2011 SP1. The rate displayed is just cosmetic and the model should still run at the rate you've specified. To fix the displayed rate, you can click on Refresh it should update to the actual rate specified.
(6,678 Views)
Yes, it was a bug.
Thx!
(6,673 Views)
