08-14-2012 10:29 AM
I wanted to know is there anyways to write (input) data to channels (aliases) in labview by using api.
08-14-2012 10:51 AM
The VeriStand API in Labview lets you Set and Get values from any VS channel. If you want to map and input to an output you will have to set up the channels in VeriStand and map them when you are creating your workspace.
08-14-2012 10:55 AM
Thank you, is there any example or detailed procedure so that i can have look at it .
08-14-2012 11:10 AM
Check out the shipping examples found in
C:\Program Files\National Instruments\LabVIEW 2011\examples\NI Veristand\API\Execution API\Deploy and Read Channels
The basic idea is you open up a link to your workspace, drop in a read or write API vi, connect up the channels you want to r/w to, and close the workspace ref.
If the examples don't help, I can post some code.
Good Luck!
08-15-2012 12:30 PM
Thank you, It would be rally helpfull if u give some codes since i'm new to veristand.
08-15-2012 12:54 PM
Try this. I actually got this from NI, but it was the quickest example I could find. I have used the advanced concepts for several GUI implementations working with VeriStand. I hope you are familiar with Labview, there is not a lot of documentation, but ask if you have questions.
08-16-2012 11:03 AM
HI,
I have wriiten a code in LV 2011 which is attached. I have tried to intialise the veristand engine bz giving a delay at start, the code is working fine. But the problem is i'm not able to write data to the channels which are created by aliases in the config file through the encircled new val. I tried putting inside the flat structure but wen i do that i won't be able to change the number, it reamins constant. So is there any other method .
08-16-2012 12:11 PM
I know there are some issues of when you can use aliases, and I don't think you can when you are doing the read and write commands ( I would use the API VI's for readability). I would use the GET ALIAS LIST.VI and then do a search for the corrisponding full channel name and use that for the Read/Write.
