VeriStand
Help interpreting VeriStand crash report
If VeriStand 2014 is left running for a few days, it will eventually crash. I run VeriStand on other test stands and its very stable. Based on this, i'm sure that the crash is related to a unique piece of code (custom device, model, etc...) or setup for VeriStand on this test stand.
Attached is the error log. I need help to interpret the error log to narrow down the issue. Normally I would just remove a piece of the code and let run to see if it crashes, but this project is quite large it would take quite a bit of time to troubleshoot in this method.
Going through the error log I did find this message, but i don't really understand how to fix it.
C:\Users\Public\Documents\National Instruments\NI VeriStand 2014\Custom Devices\NHR Power Module Rack\Data\NHRDCPowerModule.dll
ExtFuncDWarnOnCorruption: connectorTDR is
TDR (1/2): @0x0000: 'NHRDCPowerModule_ReadArray': 8
@0x0000: 'return type':
@0x0004: 'Vi':
@0x0008: 'MeasurementsBufferSize':
@0x000C: 'Measurements': [V0]
@0x0000: '':
@0x0010: 'Method':
@0x0014: 'ValBuff
TDR (2/2): erSize':
@0x0018: 'Val': [V0]
@0x0000: '':
@0x001C: '':
@0x0000: 'ValActualSize':
Little bit of background for this project:
VeriStand deploys to windows target for NH Reseach Power Supply and it also deploys to cRIO9081 with 9144 EtherCAT chassis. The project contains multiple custom devices and models.
Damian
(4,463 Views)
Accepted by Damian_S
This kind of report should be sent to NI support.
They might provide a solution for this, or at least be aware of this behavior.
Guilherme Correa
(4,444 Views)
Hi Guilherme,
Thanks for the advice. I'll contact support regarding this issue.
Damian
(4,440 Views)
