VeriStand
HP Loop duration increases with two FPGA on PXIe-1082, HP count increases
?? There is no problem with the VeriStand FPGA Interface. There is a problem with a VeriStand-project with more then one FPGA.
Message 11 of 14
(1,327 Views)
Accepted by Rokot
My guess is that the synchronization doesnt work.
Either the clock is not shared on trigger line. Or is not imported on the slave FPGA. Or wrong set of NIVS FPGA template vis were used...
CLA, CTA
Message 12 of 14
(1,318 Views)
Yes, there is a difference in the FPGA code between the project (C:\Users\Public\Documents\National Instruments\NI VeriStand 2016\FPGA) and a project that I created with the project wizard under VeriStand Custom FPGA Project that comes with the VeriStand FPGA-Based Interace I/O Tools http://forums.ni.com/t5/NI-Labs-Toolkits/NI-VeriStand-FPGA-Based-I-O-Interface-Tools/ta-p/3493285.
VeriStand Custom FPGA Project:Sync_Custom_VS1.JPG
Timing:
So there is no Timing/Sync.
C:\Users\Public\Documents\National Instruments\NI VeriStand 2016\FPGA:
Message 13 of 14
(1,307 Views)
Accepted by Rokot
Yep. On the first picture is visible, that the set of vis was cRIO/sbRIO version. You need to use the set for PXI...
CLA, CTA
Message 14 of 14
(1,299 Views)
