VeriStand
Exemple Play waveforms
How this example works ?  because i had always an error
(6,310 Views)
Error 1172 occurred at Error calling method NationalInstruments.VeriStand.ClientAPI.Factory.GetIStimulusProfileSession, (System.Reflection.TargetInvocationException: Une exception a été levée par la cible d'un appel.
    Inner Exception: NationalInstruments.VeriStand.VeriStandException: )
(6,309 Views)
I would make sure to open the file Waveform Player Example.vi, not Play Waveforms.vi, which was not intended to be shipped. This VI will be removed from future versions of the product. It used to be a subVI of Waveform Player Example in earlier versions of the example file, but was removed at some point.
Let me know if you have any trouble with Waveform Player Example.vi, which was tested and should work properly. Thanks!
Jarrod S.
(6,291 Views)
It is ok now ! The mistake was with the target. I dont know why but auto target doesnt work
Thanks you!
(6,286 Views)
