VeriStand
Datalogging API error with VS 2010
We are using the VS Data Logging API to record channels in a system with two targets: the first runs at 200 Hz and the second at 100 Hz.
The rate set in "Data Log File Configuration" cluster is 200 Hz.
We can get the channels recorded bu the number of samples is different for the channels. Some of them have 400 samples, others 800 and other 2000.
I could associate the 400 and 800 to the target rates but not the 2000.
We set the "Maximum streamed channels" from 512 to 2000 in both targets but the problem is still present.
Checking the installed software in the target using MAX I noticed an item "Network Streams" as option to install. Is it necessary to be installed?
As we have the target at different rates, is the maximum record rate limited to the lowest target rate?
Cheers,
CHCastro
Message 1 of 1
(6,600 Views)
