VeriStand
Compiling Simulink model for linux RT target error
Hello!
I've been attempting to compile a model in simulink with the 'NIVeriStand_Linuyx_64.tlc' target file. I have downloaded the only version of LabView Realtime (2019) that I could according to the instructions. However I get the same error when attempting to compile. My MATLAB version is R2017b and I am using VeriStand 2018 SP1 with the patch installed.
=== Build (Elapsed: 23 sec) ===
    ### Generating code and artifacts to 'Model specific' folder structure
    ### Generating code into build folder: C:\Users\Digital\Desktop\MATLAB_models\WD2_niVeriStand_Linux_64_rtw
    Warning:Root level output logging in 'Dataset' format is not supported in this simulation or code generation mode for model 'WD2'. No data will be logged.
    ### VeriStand 2018.1.1.0 (2018 SP1f1) code generation started
    ### Invoking Target Language Compiler on WD2.rtw
    ### Using System Target File: C:\VeriStand\2018\ModelInterface\tmw\target\NIVeriStand_Linux_64.tlc
    ### Loading TLC function libraries
    ### Initial pass through model to cache user defined code
    ### Caching model source code
    ### Writing header file WD2_types.h
    ### Writing header file WD2.h
    ### Writing header file rtwtypes.h
    ### Writing header file builtin_typeid_types.h
    ### Writing header file multiword_types.h
    ### Writing header file zero_crossing_types.h
    ### Writing source file WD2.c
    ### Writing header file WD2_private.h
    ### Writing header file rtmodel.h
    ### Writing source file WD2_data.c
    ### Writing header file rt_nonfinite.h
    ### Writing source file rt_nonfinite.c
    ### Writing header file rt_defines.h
    ### Writing header file rtGetInf.h
    ### Writing source file rtGetInf.c
    ### Writing header file rtGetNaN.h
    ### Writing source file rtGetNaN.c
    ### TLC code generation complete.
    ### Generating TLC interface API.
    ### VeriStand 2018.1.1.0 (2018 SP1f1) Modifying source file WD2.c
    ### VeriStand 2018.1.1.0 (2018 SP1f1) Modifying source file WD2_data.c
    ### VeriStand 2018.1.1.0 (2018 SP1f1) Writing header file ni_pglobals.h
    ### VeriStand 2018.1.1.0 (2018 SP1f1) Modifying header file WD2.h
    ### VeriStand 2018.1.1.0 (2018 SP1f1) Generating Ports Readme file
    ### VeriStand 2018.1.1.0 (2018 SP1f1) Generating Signals Readme file
    ### VeriStand 2018.1.1.0 (2018 SP1f1) Generating Parameters Readme file
    ### VeriStand 2018.1.1.0 (2018 SP1f1) Copying support files
            1 file(s) copied.
            1 file(s) moved.
            1 file(s) copied.
            1 file(s) copied.
    ### VeriStand 2018.1.1.0 (2018 SP1f1) code generation done
    ### VeriStand 2018.1.1.0 (2018 SP1f1) code compilation started
    ### Processing Template Makefile: C:\VeriStand\2018\ModelInterface\tmw\target\NIVeriStand_Linux_64.tmf
    ### Wrapping unrecognized make command (angle brackets added)
    ###    <C:\VeriStand\2018\ModelInterface\tmw\toolchain\Linux_64_GNU_Setup.bat && cs-make>
    ### in default batch file
    ### WD2.mk which is generated from C:\VeriStand\2018\ModelInterface\tmw\target\NIVeriStand_Linux_64.tmf is up to date
    ### Building WD2: .\WD2.bat
    C:\Users\Digital\Desktop\MATLAB_models\WD2_niVeriStand_Linux_64_rtw>set MATLAB=C:\Program Files\MATLAB\R2017b
    C:\Users\Digital\Desktop\MATLAB_models\WD2_niVeriStand_Linux_64_rtw>C:\VeriStand\2018\ModelInterface\tmw\toolchain\Linux_64_GNU_Setup.bat   && cs-make -f WD2.mk  ISPROTECTINGMODEL=NOTPROTECTING EXT_MODE=0 EXTMODE_STATIC_ALLOC=0 TMW_EXTMODE_TESTING=0 EXTMODE_STATIC_ALLOC_SIZE=1000000 EXTMODE_TRANSPORT=0 MAT_FILE=1 NIDEBUG=0 NIOPT="Default" OPTS=""
    Setting environment for using NI Linux Real-Time 2017 64-bit tools.
    Error locating the NI Linux Real-Time 2017 toolchain. Confirm the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2017 was properly installed.
    ### Aborted due to an error in the build procedure for model: WD2
    Error:Error(s) encountered while building "WD2"
(5,284 Views)
Hey brayfalls,
That is the incorrect download. There is a problem with our site, and you were directed to the wrong software.  You don't actually need the Real-Time Module. You need the NI Linux Real-Time compile tools for Windows.
I am currently working on getting the public link for the download back up and will post here with a link when it is available. If this is an urgent request, you can create a service request, and we should be able to get you the correct software.
Andy
Product Support Engineer
(5,275 Views)
I'm using LV 2017 and VS 2017 and I'm not able to compile a VI like a model for Linux target. It is related to this post?
I opened this post:
https://forums.ni.com/t5/NI-VeriStand/Error-15-occured-at-Compile-DLL-Stub-for-linux-vi/td-p/3947055
(5,212 Views)
Looks like the same problem just LabView instead.
(5,210 Views)
I opened a service request some days ago... For me it is urgent. I'm going to inform the AE.
Fabio
(5,207 Views)
Accepted by brayfalls
Hello all,
All of the download links for Eclipse and GCC should be back up now. In case you still get redirected, I had to clear the cache for my browser in order to not get to the pages.
Andy
(5,165 Views)
