VeriStand
Add msg System explorer error
Hi
Is it possible to add a msg in the "System explorer error"  Window ?
For example, i create a custom device for a specific board. From the system explorer i detect if the board is present in the current PXI chassis. But if i change the Controller IP, and the board is not avaiable in the new controller, i want to add a msg to tell the user that this configuration will not work ...
Can i do such sort of thing ?
Thanks ....
(6,208 Views)
Hello kabooom,
Welcome at National Instruments Discussion Forum.
I haven't found which .NET constructor may have access to what you need. How about placing a button on your interface that launches a hardware test ?
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
(6,183 Views)
Hi kabooom,
similar functionality was implemented in
NI VeriStand Add-On - Scan Engine and EtherCAT
There is also source code available, so you can have a look at that.
Jiri Keprt
SE RTT&HIL
CLA, CTA
(6,178 Views)
I have just noticed, that this functionality is password protected.
So unfortunately, this will not help.
Jiri
CLA, CTA
(6,171 Views)
