VeriStand
2-D array of strings in "get/set item property"
I am porting some code from veristand 2009 to 2010 and I noticed that the get/set item property vi doesn't work the same. Specifically, I can't write or read 2-d strings sent as variants. When I put the 2-d array in a cluster it works fine. Anyone have some information on this?
JY
Message 1 of 11
(8,630 Views)
Howdy JY,
Looks like you are working with a custom device. I am understand what you mean when you can't read or write 2D strings sent as variants. Is it that the Set or Get does not read back the correct value, do you get an error? Do you have a snippet that shows the issue you are seeing?
Joshua B.
Message 2 of 11
(8,606 Views)
Here is an example of what I tried to do and what I had to do as a work around.
JY
Message 3 of 11
(8,598 Views)
Hi JY,
Thanks, I'll give this a shot on my system and let you know what I find out.
Joshua B.
Message 4 of 11
(8,572 Views)
Hi JY,
Just wanted to let you know that I have been out of the office the last couple of days, but I haven't forgotten about you! I'll let you know what I find out. Sorry for the delay.
Joshua B.
Message 5 of 11
(8,525 Views)
Hi JY,
I see what you are seeing, I'll need to discuss the issue with NI R&D. I'll let you know what I find out. Sorry for the delay.
Joshua B.
Message 6 of 11
(8,491 Views)
Accepted by jeffyy
Hi JY,
This issue has been reported to NI R&D as Corrective Action Request (CAR) 287960 for further investigation. Thanks for the feedback!
Joshua B.
Message 7 of 11
(8,425 Views)
has this been addressed yet?
JY
Message 8 of 11
(7,800 Views)
Yes. This issue was fixed in NI VeriStand 2011.
Jarrod S.
Message 9 of 11
(7,777 Views)
i see. so i didn't have to change my code?
jy
Message 10 of 11
(7,768 Views)
