‎07-02-2007 09:38 AM
‎07-23-2007 10:51 AM
There are no revision issue between the controllers and the PC interface, even if this situation seems to be related to a sort of malfunctioning dued to controller type and host machine. How often daes it happen?
Has this problem been always present since the system starts working with that PC interface?
Have you already try to reinstall NI-VXI on these controllers?
Let's me know.
Riccardo
‎07-23-2007 11:16 AM
Has this problem been always present since the system starts working with that PC interface? yes,
Have you already try to reinstall NI-VXI on these controllers? no I did not re-loaded any sw , tell me more on this..
I have also the suspect of the system power supply generating the voltage for the VXI chassys, but already replaced and monitored.
thanks
‎07-24-2007 04:30 AM
‎07-26-2007 02:27 AM
Have you already verify that the configuration procedure of VXI-MXI-2 has been realized correctly?
Is an unique local address associated to every chassi? Concerning this aspect, you can find a guideline at this link:
http://forums.ni.com/ni/board/message?board.id=350&message.id=1133
Besides, what daes it happen exactly? The chassi or the boards inside disappear?
Let's me know.
Kind regards.
Riccardo
‎11-28-2007 05:53 AM
Are you by chance using removable hard drives?
Have you contacted Teradyne directly about this issue?
Kevin C.
