VXI and VME
ordinal 215 not found in visa32.dll
I'm trying to port code that was developed in LabView 6.0 to LabView8.2.  When I attempt to run the code, I get the following error message:
"The ordinal 215 could not be located in the dynamic link library VISA32.dll".
This error seems to pop up whenever I make a call to the any of the VXI vi.  Currently, we have NI-VXI 3.3.1 and VISA 4.0 installed, and we have a MXI-2 PCI card installed in the PC.  The precompiled version of the LabVIEW 6.0 code works on the same PC.
Thanks in advance
(7,515 Views)
Hi Carl_Ray,
After installing LabVIEW 8.20, did you reinstall VISA and VXI so that these drivers support version 8.20? I would repair the installations of both drivers. Does that change the behavior you are seeing?
Missy S.
Project Engineer
RoviSys
(7,470 Views)
I found out what the problem was.  It had another version of the VISA32.dll driver sitting in my working directory, so LabView was refering to that when it runs.  After I removed that file, the error went away.
Carl
(7,442 Views)
Hi Carl,
I'm glad to hear you found the cause of the problem! Happy programming!
Missy S.
Project Engineer
RoviSys
(7,436 Views)
