キャンセル
次の結果を表示
次の代わりに検索
もしかして:
need VME-PCI8026 to run on Linux kernel 2.6.x
I am still running with version 1.6.2 (on kernel 2.4) although versions through 2.0.1 have been made available to me. Last time I tried, 2.0.1 almost worked but I encountered a very intermittant problem, and had to revert to 1.6.2, to make a milestone. So, if your 2.0.1 (or later) driver is available on kernel 2.6, I could give it another shot..
0 件の賞賛
メッセージ1/5
7,687件の閲覧回数
Hi doman,
At this time there are no drivers available for the 2.6 Kernal of Linux. We also don't have any information regarding if this kernal will be supported in future versions of the VXI driver. Keep an eye on the VXI site for updates, but at this time we offer no support for that kernal.
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
0 件の賞賛
メッセージ2/5
7,673件の閲覧回数
Doman,
You may want to go through the e-mail support site (www.ni.com/support) and send in a support e-mail asking for more information regarding this. Those are a little easier to get bumped up to the R&D teams. We might be able to get a little more information to you through that means.
-Matt S.
0 件の賞賛
メッセージ3/5
7,661件の閲覧回数
Since NI is not providing Linux 2.6 support, I've ported NI's 2.0.1 ni-vxi kernel module to run on the 2.6.12.6 kernel. You can get it here:
http://66.92.150.218/misc/nivxi_module26_2005_09_21.tar.gz
It seems to work fine with the pci-mxi-2 at least.
0 件の賞賛
メッセージ4/5
7,643件の閲覧回数
If you read this... How did you get 1.6.2 to work with kernel 2.4 ? Mine simply refuses to compile!
0 件の賞賛
メッセージ5/5
7,267件の閲覧回数
