NOTE: The information on this page only pertains to LabVIEW 2015 64-bit and earlier. The VI Analyzer Toolkit is fully supported (including installers) for 64-bit LabVIEW on Windows, Mac, and Linux, with LabVIEW 2016 64-bit and later.
The VI Analyzer Toolkit installer for LabVIEW 2015 and previous only works with a 32-bit LabVIEW installation. The following steps (valid for LabVIEW 2009 through LabVIEW 2015) allow you to manually install the VI Analyzer Toolkit to 64-bit LabVIEW. These steps assume you have a valid license for LabVIEW 32-bit, LabVIEW 64-bit, and the VI Analyzer Toolkit.
Note - This procedure has not been formally tested by National Instruments, and thus is not officially supported. If you have any issues following these steps, please post them in the comments thread on this document, and not on the NI support forums.
Once you have followed these steps, you should be able to use the VI Analyzer Toolkit in LabVIEW 64-bit. If, however, you encounter a licensing error when opening VI Analyzer VIs in 64-bit LabVIEW, you may need to follow these additional steps:
Fixing Licensing Issue with VI Analyzer Toolkit and 64-bit LabVIEW
I was able to copy the files, but I get a license error when I try to use them in LV2013 SP1 64-bit.
I am able to use 32-bit LV2013 SP1, and also 32- & 64-bit versions of LV 2012-2010 without a problem.
I have LabVIEW 2013 SP1 32-bit and 64-bit installed on my system, and the licenses for LabVIEW and the VI Analyzer Toolkit look fine:
I followed the steps in this document exactly, and the VI Analyzer Toolkit (both the API and the UI) work fine in LabVIEW 2013 SP1 64-bit. I'm not sure what the problem could be on your system.
We were able to solve D*'s issue with some modifications to his registry. I have added the steps required for this modification to the main document.
Tried and succeeded with LV2015SP1, Ubuntu 14.04.
For convenience, this is a script for doing the copying part of 4. above, from shell (sudo).
#!/bin/bash
SOURCE32=/usr/local/natinst/LabVIEW-2015
TARGET64=/usr/local/natinst/LabVIEW-2015-64
for f in \
"examples/VI Analyzer Toolkit/" \
"help/lvvian_f.bin" \
"help/lvvian_t.bin" \
"help/lvvian_w.bin" \
"manuals/VIAnalyzer_User_Guide.pdf" \
"menus/Categories/Programming/_VIAnalyzerTK" \
"menus/Categories/Programming/_VIAnalyzerTK.mnu" \
"project/_VI Analyzer/_tests/" \
"project/_VI Analyzer/testcreator.llb" \
"project/errors/" \
"readme/readme_VIAn.html" \
"resource/Framework/Providers/VI_Analyzer_Toolkit/" \
"resource/Framework/Providers/GProviders/VI_Analyzer_Toolkit.ini" \
"vi.lib/addons/analyzer/analyzerapi.llb" \
"vi.lib/addons/analyzer/NI_VIAnalyzerTKVIs.lvlib"
do
cp -rf "$SOURCE32/$f" "$TARGET64/$f"
done
Thanks Enrico for posting this helpful information for Linux VI Analyzer users!
Hey all, this tripped me up. I ran the registry fix right from the RAR file in a temp folder (didn't save it just opened it from firefox). Though windows said it applied it, it never put the keys in the registry. Saving the file I needed to the desktop and then running it actually added the keys and the analyzer works.
Thanks Evan, I have updated the instructions to mention explicitly unzipping the files before using them.
I have followed the instructions and double checked everything, but when I run the VI analyzer the list of tests is missing?
DDTun, I don't know what the problem could be. Carefully following these instructions has worked every other time.
Hi Darren, problem was fixed by installing 2016 version, thanks anyway.
