VI Analyzer Enthusiasts Discussions
Spell Check Locks Up
So I'm having some instances where the Spell Check test just locks up.  I let it go for 20 minutes and it never got any farther.  I can see that it is getting stuck in the Extract and Process Data--FP Control.vi VI when scanning a particular VI.  Making troubleshooting more difficult is this VI is password protected.  I can see in the VI but I couldn't find any reason to lock it up.  But since that is in an LLB, that is part of a passworded library, making edits, or debugging is difficult.  I might try to make my own Spell Check2 test that I can debug more but has anyone seen this?  Is there a reason to lock this VI?  Thanks.
(3,296 Views)
Weird, there are a couple of while loops in that code but I've never seen them loop forever. Maybe it's one of those, or maybe there's a bug in some property node in that code causing it to hang? I also don't see off-hand why the VI is password-protected, maybe there's a hidden private property nested in the code somewhere. Anyway, tell me what LabVIEW version you're using and I'll post an unlocked version of that VI you can drop-in to your code to debug, I'm curious to see what you find.
(3,287 Views)
Accepted by topic author Hooovahh
Egg on my face time.  So it isn't locking up in that VI, it is actually in a subVI of that VI, Break Strings.vi. And it isn't locked up, my VI just happened to have some MCLB with a very large amount of rows.  This resulted in a string with over a couple million characters going into the Break Strings.vi which seemed like locking up but really it just took forever.  There really isn't a better way to handle this other than having a limit on the string length and a warning afterwards being like "Bro you probably have some constants somewhere that need clearing."
(3,281 Views)
Gotcha, thanks for posting the follow-up. I've run into similar issues. The Icon Editor source code has some hard-coded constant VIs containing large amounts of picture data in them (for when glyphs can't be downloaded from ni.com). Right now the Ctrl-F text search looks inside picture strings (a bug if you ask me), so whenever you do a Ctrl-F on the Icon Editor source to search for text it takes forever.
(3,278 Views)
