From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
09-01-2022 01:37 PM
So I'm having some instances where the Spell Check test just locks up. I let it go for 20 minutes and it never got any farther. I can see that it is getting stuck in the Extract and Process Data--FP Control.vi VI when scanning a particular VI. Making troubleshooting more difficult is this VI is password protected. I can see in the VI but I couldn't find any reason to lock it up. But since that is in an LLB, that is part of a passworded library, making edits, or debugging is difficult. I might try to make my own Spell Check2 test that I can debug more but has anyone seen this? Is there a reason to lock this VI? Thanks.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
09-01-2022 01:59 PM
Weird, there are a couple of while loops in that code but I've never seen them loop forever. Maybe it's one of those, or maybe there's a bug in some property node in that code causing it to hang? I also don't see off-hand why the VI is password-protected, maybe there's a hidden private property nested in the code somewhere. Anyway, tell me what LabVIEW version you're using and I'll post an unlocked version of that VI you can drop-in to your code to debug, I'm curious to see what you find.
09-01-2022 02:15 PM
Egg on my face time. So it isn't locking up in that VI, it is actually in a subVI of that VI, Break Strings.vi. And it isn't locked up, my VI just happened to have some MCLB with a very large amount of rows. This resulted in a string with over a couple million characters going into the Break Strings.vi which seemed like locking up but really it just took forever. There really isn't a better way to handle this other than having a limit on the string length and a warning afterwards being like "Bro you probably have some constants somewhere that need clearing."
09-01-2022 02:27 PM
Gotcha, thanks for posting the follow-up. I've run into similar issues. The Icon Editor source code has some hard-coded constant VIs containing large amounts of picture data in them (for when glyphs can't be downloaded from ni.com). Right now the Ctrl-F text search looks inside picture strings (a bug if you ask me), so whenever you do a Ctrl-F on the Icon Editor source to search for text it takes forever.
