01-14-2015 02:58 AM
I am trying to run wireless video link example https://decibel.ni.com/content/docs/DOC-22728 . It works fine if I use install antennas on my Tx and Rx USRPs. But it does not work if I use SMA to SMA cable to connect Tx and Rx USRPs. Can somebody guide me what is the reason why it is only workng with antennas but not with SMA to SMA cable.
JK
01-14-2015 05:51 AM
01-14-2015 06:07 AM
Do you mean to say I should use attenuator both with Tx and Rx?
01-14-2015 06:42 AM
Also plz guide me where should I connect the attenuator?
01-14-2015 06:49 AM
Let me add one more thing I am using two separate usrps. One is Tx and another is Rx.
01-14-2015 06:53 AM
for connecting multiple USRP devices to each other, you must connect a 30 dB attenuator to the RF input (RX1 or RX2) of each receiving USRP device.
So does it mean I need to conect 30 dB attenator to my RF input only right??
Please guide
JK
01-14-2015 07:30 AM - edited 01-14-2015 07:31 AM
I connect the 30 dB attenuator at RF input port of Rx USRP. But it does not work completely.
Without connecting attenuator i was not able to receive any thing on my Rx VI although it shows waveform. But after connecting attenuator receiver some times receive text messages and some times not. Also it does not work at all for images and for video it works partially but gives some error related to memory full after few mins.
I want to know why this example works completely without any problem if I use antennas, and why it does not work perfectly if i use sma to sma cable for connecting transmit and receive usrps.
Please guide
JK
01-14-2015 08:52 AM
01-14-2015 09:55 AM
Can you tell me in which VI its value is define. So that I can change the value from there.
01-14-2015 10:03 AM
