USRP Software Radio
will labview support x310 usrp
Hi to all
i have an x310 usrp with twinrx daughter board  and i want to use it with labview...i want to ask if labview can support that and how??
(3,083 Views)
Accepted by topic author OsamaAhmed
Hi There,
The x310 is supported in LabVIEW. Searching 'x310 LabVIEW' (without quotes) on Google yielded the following result for me:
Where to Find LabVIEW Examples for USRP X310
In that article there is a link to the Readme for NI-USRP that calls out the compatibility of various USRP devices as well as daughterboard support. The same readme file contains installation instruction and the KnowledgeBase article points to the location of the installed Examples.
Alex W.
(3,055 Views)
Do you want to use the device with the NI-USRP LabVIEW API, or do you want to use LV-FPGA and customize the FPGA code?
Both are possible, but you'd need to update the Flash to use the X310 with LV-FPGA and those daughterboards.
(3,041 Views)
(3,035 Views)
