what is usrp block chain for transmitting side ? and mathematically what happen to signal in each stage for real and complex signals ? and if the input baseband signal for usrp transmitter larger than [-1 1] what happen and what is the solution to make the signal proper as input in this case?
if you want to get an idea of the USRP transmission chain, I suggest you to take a look at the examples contained in the LabVIEW palette you can reach selecting Express -> Output -> Instrument Drivers -> NI-USRP -> Examples (niUSRP), available after installing NI-USRP.The example named niUSRP EX Tx Continuous Async.vi, of which I put a snippet below, may be particularly useful to you.
