USRP Software Radio
transmit DC signal but receive signal unexpected, why?
I have done two tests to transmit DC signal with NI-USRP 2920 and the parameters are as follow:
common parameters:
1-carrier frequency: 200MHz
2-IQ Rate: 200kHz
3-Transmit Gain: 20dB
for test-A:
Transmit Signal:
 When the receive gain is 0dB, the received signal is
When set the receive gain is 20dB, the received signal isA-2.pngA-2-zoom in.png
for test-B
Transmit signal:
When the receive gain is 0dB, the receive signal is:
I want to know why I cannot receive a signal similar to DC(that is, I expect that I will receive a DC plus a little noise).
In the next project, I will use QPSK modulation, but the phase flip result(that is, the transmited signal don't have negative part but the received signal do)shown above makes me upset. Can I do something to help transmit in QPSK successfully?
Thx!
Message 1 of 1
(2,156 Views)
