USRP Software Radio
Converting .bin file to rinex format
Hello everyone,
We are using LabVIEW and USRP 2932 to record Raw GNSS signals. File format in which data is stored is .bin.
Is there is any way or tool by which we can convert bin file to rinex file format?
Thanks in advance............
(5,660 Views)
USRP device samples and outputs IQ data that is stored in raw binary format.
However, RINEX files are produced by GNSS receivers and contains GNSS RAW Measurements (Pseudorange, Carrier-phase etc). You need to implement a GNSS receiver in LabVIEW or you can use the raw data (.bin file) and do post-processing in some other GNSS receiver e.g. MATLAB/ GNSS-SDR
(5,542 Views)
I use the following program to convert bin files from Hemisphere to rinex.
https://hemispheregnss.com/Portals/0/Software/Rinex_Desktop_09_2017.zip
you could also use rtklib (rtkconv) program too.
(5,443 Views)
